I am not actually running ext3, but might at some stage. Hence trying out that kernel. I'm actually using my own compile of your v291 tree which has worked pretty good for a long time. I wonder which app is causing it? I'm running a telnetd, and empacman. Did the hijack ioctl extensions change slightly in newer versions? Btw, network problem was indeed something else.
