In order for the Empeg visuals to look cool on that monitor, they would have to be re-programmed to work at a higher resolution. Some of the visuals could theoretically run at higher resolutions and color depths, but you'd need some complex and expensive video circuitry added to the Empeg, and a lot of new code to back it up.
The best thing you could hope for right now is to create some kind of add-on to the Empeg that took data via ethernet or serial, and then turn THAT into video signals. Others have discussed doing this, but it's not inexpensive and not trivial to implement.
Although it is kind of sad having a plain-old CD changer's display showing up the Empeg like that.
___________
