This one probably qualifies for its own FAQ entry by now, unless the empeg guys are planning on changing the behavior sometime soon...
In Emplode, you can sort the order of any playlists or songs at any level (including the top level). Hit View/Details, sort by position (click on the "position" column header), and drag stuff up and down in the right-hand pane.
This adjusts the
play order of songs and playlists, i.e., the order that the songs and playlists are played if "shuffle" is off.
The playlists and songs still appear alphabetically on the empeg's
menu screen when you are navigating the playlist structure. This is by design: You can access these menus alphabetically using the keypad on the remote control, so from that standpoint, the alphabetical sorting is correct.
The relative merits/problems of this system have been discussed in other threads
here and
here, and at this time, the empeg folks have not said whether or not this behavior will be changing in the future.
___________
