I don't know how to check the IDE header. Does that mean opening up the empeg and checking to see if the cable is properling crimped? I guess I'm not sure what an IDE header is.
The IDE header is where the hard disk cable plugs into the mainboard. There are some pictures in the FAQ entry I linked above where the pins are pulling away from the mainboard because of bad solder joints. Make sure you go through the ENTIRE faq entry thoroughly.
I only have a docking sled in my car, but when I use AC power to turn it on, I have the same issue with it not bringing up the previous playlist. Is that what you meant?
Yup. That pretty much rules out not getting sufficient power to the player, but there are still other possibilities. Good luck!
