You can put it on a NFS server somewhere and mount it from the empeg, this way you won't have to rebuild it when you upgrade the empeg. That is an excellent idea if Tony wants to compile directly on the empeg. Is there any NFS support in NT? That way you wouldn't be wasting drive space on the empeg and would not have to deal with setting up a cross-compile environment. You may even be able to use something like sharity to mount a windows SMB share on the empeg. -Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
