You should have said it was inside WINS. I have it set to Auto. I'll try it tonight and then play with manually turning it on to see if it makes a difference.
I'll likely still have to use the other profile tool, if ony to avoid having to enable/disable the odessey client and other VPN component each time she wants to connect to the net at home.
