No, it's a battery voltage sense; it implies your charging system is not up to the task of supplying umpty Amperes to drive your Amps & Subs; you should look at your battery condition as well, since as it ages its internal resistance (impedance) goes up which means it can actually provide less voltage when it has a high current load.
One of the few remaining Mk1 owners... #00015
