I'm trying ftp as well, and getting stuck at the same spot ... only the empeg is connected via ethernet directly to my Mac. No Linksys or anything else in the way.
I can telnet without any trouble and I can connect via serial cable without trouble.
I can establish the ftp connection. Then I try "site rw" followed by a put [file in local directory] [destination on empeg]. I get this:
500 Bad command.
502 Not implemented.
200 Okay.
150 Opening data connection.
And ... it sits there.
Basically I'm trying to update my hijack kernel on the Mac now (first time doing this on the Mac). jEmplode doesn't seem to update it, even though I have picked the menu option. Recompiling download.c from empeg-hijack (to use /dev/tty.usbserial0 which is my serial port to the empeg) and running that doesn't work. Thus I'm trying ftp now ... and I get what you see above. Hmm ...
-- JD - SN# 040104008 (120GB Blue, Digital Out)
