I dont know if this is the correct log. it is quite lengthly. through emplode I went to tools/options/trouble shooting, and then checked the box for enabling logging is this the correct way? or am i going about it all wrong? it is in a notpad application is this correct?
this shows up several times near the end of the log
I pinged 127.0.0.1 and no packets were lost
13:48:51.140 Binding to 0.0.0.0:8300
13:48:51.140 Found interface '192.168.1.100'
13:48:51.156 Trying to broadcast packet on address '192.168.1.255'
13:48:51.156 Found interface '127.0.0.1'
13:48:51.156 net_discovery.cpp(95) : I [07b0] Selecting with timeout=1666ms
13:48:51.156 net_discovery.cpp(127) : I [07b0] ReceiveFrom returned 0 response=? unit=192.168.1.100
13:48:51.156 net_discovery.cpp(167) : I [07b0] Received ? from 192.168.1.100
13:48:51.156 net_discovery.cpp(152) : I [07b0] select took 0ms
13:48:52.156 net_discovery.cpp(102) : I [07b0] Select timed out
13:48:52.156 Found interface '192.168.1.100'
13:48:52.156 Trying to broadcast packet on address '192.168.1.255'
13:48:52.156 Found interface '127.0.0.1'
13:48:52.156 net_discovery.cpp(95) : I [07b0] Selecting with timeout=666ms
13:48:52.156 net_discovery.cpp(127) : I [07b0] ReceiveFrom returned 0 response=? unit=192.168.1.100
13:48:52.156 net_discovery.cpp(148) : I [07b0] Found 192.168.1.100 again
13:48:52.156 net_discovery.cpp(152) : I [07b0] select took 0ms
13:48:52.828 net_discovery.cpp(102) : I [07b0] Select timed out
13:49:18.781 connection_win32.cpp(1058) : W [07b0] connect() failed: 10060
13:49:18.781 connection_win32.cpp(395) : I [07b0] UsbConnection(00B17AD8)::Open() device='\\?\usb#vid_084f&pid_0001#5&200e9eca&0&2#{248f0d00-0f88-11d3-9129-00104b62b7d4}'
13:49:18.781 connection_win32.cpp(444) : I [07b0] UsbConnection(00B17AD8)::Open()[C] = 0
243967-emplode.log (179 downloads)
Edited by natewhip (22/12/2004 19:39)
