Ok, When I right click on the drive and go to properties the Volume label field is empty. If I accidentally deleted that would it cause this? Also it shows up as 0Mb free of 0Mb Available. As for chkdsk, when I do this from the properties window on the TOOLS tab. I check off "Autoatically fix file system errors" and "scan for and attempt recovery of bad sectors" . When I click start, nothing seems to happen. Is this normal or should a window pop up showing the staus of chkdsk. Or am I not even in the right place???
Dave
MK2 12Gb
MK2a 60Gb
