The problem was so bad that we had to use a CD player when demoing the disco lights because there was not enough low end punch from the empeg to put on a good show.
Remember that most consumer CD players artificially boost the bass a little bit in their default mode. The empeg's output is more flat (accurate) by default. Did you try just turning up the loudness a bit?
___________
