Under what circumstances would the player app be stopped?
- When you Q or Ctrl-C or kill at a shell prompt.
- When you use a configuration tweak to add the "Quit" item to the player's main menu, and then select it from the player's main menu.
- When the player app crashes for some reason.
I'm not sure if the player app stops at any point during a synchronization operation, or if the player just receives a reboot command...
