VM: do_try_to_free_pages failed for player...
You're running out of memory. Try increasing ReserveCache.
Thanks. The empire/palantir page doesn't mention a value, so I went with 64. Caught this via TeraTerm:
Adding Swap: 16028k swap-space (priority -5)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
hdc4 is mounted.
Restored terminal settings
Restart code received
Starting player
Timezone: America/Detroit
Hijack: intercepting config.ini
Using non-standard cache size 70 (adjustment 64)
EDIT: LOL, that wasn't a good idea! The player got stuck on "Loading Music Databases". I had to restart, do a quick "q" and now it's rebuilding the database. Assuming I can get into the player via emplode after this, I'll edit out the ReserveCache line and the @execonce command for empire. I'll just wait until I get more RAM to run 3rd party aps.
Edited by SE_Sport_Driver (10/03/2005 19:46)
Brad B.
