#252374 - 23/03/2005 20:51
Re: e2fsck message at bootup, what does it mean?
[Re: bodybag]
Quote: No Peter, I've been having trouble with this player for a while now. I've done this copy & replace thing many times... before & after doing an fsck. The recent fsck was just another effort to see if I could "fix" the issue.
So have you or haven't you re-blanked and re-copied since the last failing fsck?
Perhaps it's during your copying process that you're at some point rebooting with the drives still mounted read/write? Could you describe your copying steps in excruciating detail?
Edit: Just to amplify what I said before, once fsck has fixed an error then everything on the drive is suspect and you should expect corruptions of the sort you experienced until you delete and re-copy all content. The ONLY issue here is what caused the error that fsck found.
bodybag
23/03/2005 02:41
bodybag
23/03/2005 03:04
bodybag
23/03/2005 04:24
bodybag
23/03/2005 04:29
bodybag
23/03/2005 19:27
bodybag
23/03/2005 19:50
bodybag
23/03/2005 20:18
bodybag
23/03/2005 20:45
bodybag
23/03/2005 21:04
mcomb
26/03/2005 04:23
