Actually that is one thing that is somewhat lacking under Mac OS 9. It is not really designed with multiple network interfaces in mind. She could use Location Manager to easily switch between the two though. The "right" solution would be to setup the airport base station using NAT and DHCP and give both the empeg and the mac 10.x.x.x addresses via DHCP with the airport. Then plug the empeg into the airport (or into a small hub plugged into the airport). Then she can have internet access and work with the empeg at the same time. Also, the empeg (or any other computer plugged into the hub) can have internet access at the same time. -Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
