And as soon as I try to load the next batch of songs, something hangs.
jEmplode is showing 20% complete on the very first item in the transfer activity list, "add g-h", which is the parent playlist I imported, and eventually jEmplode decided that it wasn't connected to anything. See attachment. (Before the popup window, the status of add g-h was 20%, and the completion bars reflected that.)
EDIT: Oh, and the VFD is still showing the moving synchronizing display, so presumably the player process is still active?
The console showed these additional lines right after the startup stuff I quoted a few posts back:Code:
ksock_rw(recv): error: -104
kftpd: ksock_rw() failed, rc=-104
Adding Swap: 16028k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
I telnet'ed into the unit and grabed this stuff:
Configured for mataglap-work.
Configuring loopback interface...done.
Setting hostname to mataglap...done.
Running ntpdate to update clock...
14 Apr 15:51:40 ntpdate[55]: adjust time server 192.168.168.90 offset -0.100356 sec
mataglap:/# cat /proc/meminfo
total: used: free: shared: buffers: cached:
Mem: 15241216 14495744 745472 3256320 393216 3964928
Swap: 16412672 0 16412672
MemTotal: 14884 kB
MemFree: 728 kB
MemShared: 3180 kB
Buffers: 384 kB
Cached: 3872 kB
SwapTotal: 16028 kB
SwapFree: 16028 kB
mataglap:/# cat /proc/mounts
/dev/root / ext2 ro 0 0
/dev/hda2 /programs0 ext2 ro 0 0
none /proc proc rw 0 0
/dev/hda4 /drive0 ext2 rw 0 0
mataglap:/# ps -ef
UID PID PPID C STIME TTY TIME CMD
root 1 0 0 15:40 ? 00:00:05 init
root 2 1 0 15:40 ? 00:00:00 [kflushd]
root 3 1 0 15:40 ? 00:00:00 [kupdate]
root 4 1 0 15:40 ? 00:00:00 [kpiod]
root 5 1 0 15:40 ? 00:00:00 [kswapd]
root 6 1 0 15:40 ? 00:00:00 [kftpd]
root 7 1 0 15:40 ? 00:00:00 [khttpd]
root 8 1 0 15:40 ? 00:00:00 [menuexec]
root 11 1 0 15:40 ? 00:00:00 /programs0/bin/telnetd
root 12 1 0 15:40 ttyS1 00:00:02 /empeg/bin/player
root 13 12 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 14 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 15 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 16 13 0 15:40 ttyS1 00:00:03 /empeg/bin/player
root 17 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 18 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 20 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 21 13 0 15:40 ttyS1 00:00:01 /empeg/bin/player
root 22 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 23 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 24 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 25 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 26 13 0 15:40 ttyS1 00:00:01 /empeg/bin/player
root 27 13 0 15:40 ttyS1 00:00:00 /empeg/bin/player
root 28 13 3 15:40 ttyS1 00:00:27 /empeg/bin/player
root 34 6 0 15:50 ? 00:00:00 [kftpd <defunct>]
root 36 11 0 15:51 ttyp0 00:00:00 /bin/sh --login
root 58 36 9 15:53 ttyp0 00:00:00 ps -ef
mataglap:/#
Off to reboot and fsck.
--Nathan
Edited by Mataglap (14/04/2005 21:09)
