This is an awesome app!!! I have 6 units and would love to be able to control them using my PSP.
I'm able to run the trio applet on the same box the server is running on. but not able to run it from any other machine.
I have this problem as well, and tried this suggestion
<rmi create-registry="true" host-name="xxxx"/>
and substituted xxxx with 192.168.0.3, the static ip of my server. - but it didn't work for me. I can only view the front-end on the local machine using the following URL http://localhost:8090/trio-html
I cannot even use the local machine's ip address on the local machine (http://192.168.0.3:8090/trio-htm)
I'm running WinXP SP2, tRio 0.1.6, Java 1.42. I've got no software firewall running.
Any suggestions?
Thank You!!!
