# IN UNIX ENVIRONMENT: convert DOS newlines (CR/LF) to Unix format
sed 's/.$//' # assumes that all lines end with CR/LF
sed 's/^M$//' # in bash/tcsh, press Ctrl-V then Ctrl-M
sed 's/\x0D$//' # gsed 3.02.80, but top script is easier
# IN UNIX ENVIRONMENT: convert Unix newlines (LF) to DOS format
sed "s/$/`echo -e \\\r`/" # command line under ksh
sed 's/$'"/`echo \\\r`/" # command line under bash
sed "s/$/`echo \\\r`/" # command line under zsh
sed 's/$/\r/' # gsed 3.02.80
http://www.student.northpark.edu/pemente/sed/sed1line.txt
http://www.google.com/search?q=sed+dos+unix
