Checked the FAQ's but the solution didn't really help me.
Which solution, this one here? (That one was the first search result when searching the FAQ for the terms "fast forward and rewind".)
I don't understand why it didn't help you, because it links to the exact fix that Mark is telling you to use. And it also tells you that version 1.0x software can't rewind or fast forward VBR files properly.
Are you saying that fixing the VBR headers on the file, or upgrading to version 2.0, doesn't solve your problem?
