Hi. I'm not technical enough to determine whether the logs indicate anything unusual, so I shut everything down and restarted. Below is what the log recorded.
"harry" is the name of the server and its IP is 10.0.0.4.
Any ideas?!
INFO: *******************************************************************************************
21-May-2005 19:11:24 trio.TRioServer main
INFO: Start of TRioServer. tRio Version 0.1.6, java.version: 1.4.2_07, java.vm.version: 1.4.2_07-b05, os.name: Windows 2000
21-May-2005 19:11:25 trio.http.TRioHttpThread <init>
INFO: Defaulted http document root to: c:\Program Files\tRio-0.1.6
21-May-2005 19:11:28 trio.TRioServer initRemote
INFO: RMI Registry created sucessfully on port 1099
INFO: binding rmi: rmi://harry:1099/TRioServerRemote
INFO: binding rmi: rmi://10.0.0.4:1099/TRioServerRemote
21-May-2005 19:11:28 trio.TRioServer scheduleRestart
INFO: Scheduling restart for Tue May 24 04:00:00 BST 2005
21-May-2005 19:11:28 trio.TRioUDPConnection <init>
INFO: creating udp socket. local port: 19680, timeout: 15000
21-May-2005 19:11:28 trio.http.TRioHttpThread run
INFO: Http server listening on port 8090
21-May-2005 19:11:53 trio.TRioControlThread processConnectRequest
INFO: Got connect from /10.0.0.13. ClientID: receiver, Client Version: 0.1.6, Hardware Address: 00:90:00:11:5c:52
21-May-2005 19:11:54 trio.player.TRioPlayerARMServer <init>
INFO: ARM URL settings. URL: ssdp
21-May-2005 19:11:54 trio.TRioControlThread processConnectRequest
21-May-2005 19:11:59 trio.TRioControlThread processConnectRequest
21-May-2005 19:12:04 trio.TRioControlThread processConnectRequest
21-May-2005 19:12:09 trio.TRioControlThread processConnectRequest
21-May-2005 19:12:14 trio.TRioControlThread processConnectRequest
21-May-2005 19:12:19 trio.TRioControlThread processConnectRequest
