\0x00
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v429 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Tue May 10 20:39:19 EDT 2005
Added temporary pagedir entry for flash memory access
Checking for extra DRAM:
c1000000: wrote ffffffff, read e2811004
empeg-car player (hardware revision 9, serial number 10102101) 16MB DRAM
Command line: mem=16m
Memory: 15012k/16M available (984k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x9a38c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: HTS541040G9AT00, ATA DISK drive
hda: HTS541040G9AT00, 38154MB w/7539kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:35
Partition check:
hda: unknown partition table
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08|\0x08/\0x08-\0x08\\0x08done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...\0x00X]]Y[\]H]\0x0b)kk«kÍ\0x81\0x89\0x95å½¹\0x91\0x81\0x95¹\0x91\0x81½\0x99\0x81\0x91\0x95Ù¥\0x8d\0x95)5\0x7fL&'¦\0x93\0x02\0x92ÝõÁ±\0x81Ý\0x85¹Ñõɱ\0x81±¥µ¥ÑõÁ)5\0x1fV\0x96\0x17\0x12Ó\0x93\0x82ª\0x02\0x12±­Í¥é\0x95õÅÁÉÑ\0x81\0x89±½\0x8d­¹ÉõÅ\0x81Í\0x95\0x8dѽÉõÉ\0x81Í¥é\0x95õÅÁÉÑ\0x81\0x8d½Õ¹ÑõÅ)5\0xffEXT2-fs: unable to read superblock
Kernel panic: VFS: Unable to mount root fs on 03:05
\0x00
Do I simply need to apply the Disk Builder ?
Empeg IIa - 10 Gb - Red Fascia - Tuner, the day is coming - I Will Strike From the Grey -
