#264445 - 16/09/2005 16:27
Re: jEmplode Ethernet Problem
[Re: mschrag]
Loc: Edinburgh, UK
Oh wait.
Is it possible you have a software firewall that is blocking passive ftp connections back to your machine from the Empeg?
The solution is always an obvious one!! Yep, I dug around in the system settings; disabled all firewalls and hey presto I can connect to the empeg using Hijack again. Seems Fedora 4 has some more stringent default firewall settings than Fedora 1. After a bit more fiddling I now have both a firewall and a decent empeg connection. Thanks for the conversation! Problem solved.
Cheers, Ross
