Well, you said this was a spare. You can always try swapping the display modules between your spare and main empeg. As long as you do not plug the header in off by one pin (which will blow any fuses that remain), you should be able to see if the possibly broken VFD works in the main (suspect fuses on spare) or if the known working VFD still works in the spare (suspect VFD or display board).
Paul Grzelak
