The sleeve of heat-shrink tubing actually makes a nice difference. Since I did that I haven't been bothered by the led.
I remember hearing about this technique. I might have to try it.
You mean if the player is on and playing songs and showing stuff on the display, the LED is still on? That's not the way it's supposed to be. If that's what's happening to you, you've got a bigger problem. RobS will probably have to chime in on this one.
On and playing songs, and Off and just sitting in the sled... Solid illuminated LED. This is only while in the car sled. When it's plugged in at home it behaves normally and I was able to turn it off in hijack.
Try also setting standbyLED_off=0
I'll give that a shot. I have to hit the road here soon, but I appreciate the help everyone.
Brian H. Johnson
MK2 36GB Blue, currently on life support
"RIP RCR..."
