Also, if you let me know how you delt with the cage for the other DIN and the Empeg sled, that would be very helpfull. Right now I am not using the mounting cage for the alpine. Its held in there as if was the lower half of a double din. (Its screwed to the sides of the Metra mounting kit.
Sounds like what I did. I didn't use the cage for my Pioneer unit either. I screwed it to the dash kit. To mount the empeg cage I enlarged the top hole in the kit and then used some of that double sided foam tape (like 1/16 inch thick) to attach the empeg's cage to the top of the Pioneer. I also used the tabs on the empeg's cage, but there isn't much material for them to press against so I think the tape is doing most of the work. It also keeps the stereos from rattling against each other.
It seems like I should take out the center din separator and bolt the cages together.
I left it in as it is about the same thickness as the tape I used and I need a little clearance between the units for the LCD screen in the Pioneer to be able to slide out. If you can find a way to bolt the two stereos together I don't see why you couldn't remove that separator. It would decrease the amount of material you need to remove to accommodate the empeg.
Thanks for the pics and help!
No problem, I'll be home in an hour or so and get some pics for you.
-Mike
