My only problem with TiVo is that it can be deathly slow sometimes. Sometimes I can tell it to record a show and then go make a sandwich before it's ready again. Anyone with the HDDirecTiVo have the same problem? I'm trying to decide if my drive might be dying.
Yep, that's just the way it is. If you aren't having other problems then it's unlikely your drive is bad. You can speed it up by not having the live buffer on a HD station. The music stations are the best as then the buffer isn't recording at all and it frees up resources on the machine to access it's database.
Great tip! I'll try that!
