Hey guys. I have pretty new EMPEG mk2 and the dimmer seems to have a mind of its own. I have it at 100% dimmer (full brightness) but the brightness seems to randomly go between lowest and highest eventhough the setting stays at 100%. The broghtness only changes when the unit is powered off/on, not when the unit is on. (it does not randomly change under normal operation... only random with each power on..
I can go into the settings and flip it to 90% then back to 100% and it corrects itself.
My other Empeg mk2 does not do this. They are running the same (most up to date) os.
Thanks for any imput you may have!!!
