#276311 - 24/02/2006 16:12
Re: PCATS tuner finally done and tested - WOO HOO!
[Re: jbrinkerhoff]
Into the sled, and powered it via the AC adaptor (into the jack on the empeg). TUNER shows up under sources, but when selected I get a BLANK screen.
Try pressing "info" on the remote, to change from that blank visual to something more useful. That's probably all it was.
If not, then my dock here provides power via the harness as well as using the AC jack to select "AC/Home" correctly, so maybe it does require power over the docking connector, even when the firmware/software is *really* in AC mode.
