Ok, I hooked the empeg up to record the bootlog. It seems to only start when 16M of RAM are detected, so you were right on. This is a bootlog when it booted normally:
CCCV
ɁɅŹɁف՝5)If there is anyone present who wants to upgrade the flash, let th
em speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v444 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Dec 2
14:42:18 EST 2005
Checking for extra DRAM:
c10000f4: wrote 00ff00ff, read 00ff00ff
empeg-car player (hardware revision 9, serial number 10101626) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATMR04-0, ATA DISK drive
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N040ATMR04-0, 38154MB w/1740kB Cache, CHS=4864/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman ([email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:5a
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5change_root: old root has d_count=1
Mounting proc
Starting player
layer redirected to /proc/ttyH
UKѱѥMѡ}ɝ)5*K+kkKJѕɍѥ)5Empire: Version 0.40 starting...
hijack: removed menu entry: "Hard Disk Detection"
khttpd: listening on port 80
kftpd: listening on port 21
IrDA: Registered device irda0
And this is the bootlog with the sigkill-error:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
14:42:18 EST 2005
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 10101626) 32MB DRAM
Memory: 31232k/32M available (984k code, 20k reserved, 528k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
TCP: Hash tables configured (ehash 32768 bhash 32768)
kmem_alloc: Bad poison (name=size-65536)
kmem_alloc: Bad poison (name=size-128)
Unable to handle kernel paging request at virtual address 0000547c
memmap = C0004000, pgd = c0004000
*pgd = c0131801, *pmd = c0131801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c002b078>] lr : [<0000547c>]
sp : c0187e78 ip : c1fa5fc0 fp : c0187e94
r10: c011a394 r9 : c0126438 r8 : c01f9b80
r7 : 00000015 r6 : 00000000 r5 : 00008124 r4 : c0183140
r3 : 00000007 r2 : a5c32f2b r1 : 00000015 r0 : 0000004b
Flags: nZCv IRQs off FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 1, stackpage=c0187000)
Stack:
c0187e60: 0000547c c002b078 60000093 ffffffff c010a82c 00008124
c0187e80: 00000006 00000000 c0187ebc c0187e98 c0059524 c002b00c c00f60f0 c1fa5340
c0187ea0: c010a82c c1fa5340 c012d8f4 c01f9ae0 c0187ed8 c0187ec0 c00a5c14 c00594d8
c0187ec0: c012d948 c012d8f4 00000001 c0187efc c0187edc c00a5d18 c00a5be0 c01f9b80
c0187ee0: c012d995 c012d840 c01f9ae0 00000000 c0187f20 c0187f00 c00a5dd0 c00a5cd0
c0187f00: c01f9ae0 00000000 c00f4ee8 ffffffff c009ac3c c0187f34 c0187f24 c00a5e1c
c0187f20: c00a5d74 c011df80 c0187f44 c0187f38 c00a06e8 c00a5dfc c0187f58 c0187f48
c0187f40: c00a0bf4 c00a06dc 000000ff c0187f84 c0187f5c c009c784 c00a0be0 00000001
c0187f60: c0102768 c0123a30 c010a788 c01246e4 4401a11b c0008580 c0187f94 c0187f88
c0187f80: c00a0c18 c009c6bc c0187fb4 c0187f98 c0046d10 c00a0c10 00000001 c0102768
c0187fa0: c0123a30 c010a788 c0187fdc c0187fb8 c0009ae0 c0046d0c 00000000 c0009ba8
c0187fc0: c012d9ac c0102760 c0102764 c0102988 c0187ffc c0187fe0 c0009bb8 c00099c0
c0187fe0: c0009ba8 c012d9ac c0102760 c0102764 c0101fd8 c0188000 c000b6ec c0009bb4
Backtrace:
Function entered at [<c002b000>] from [<c0059524>]
r7 = 00000000 r6 = 00000006 r5 = 00008124 r4 = C010A82C
Function entered at [<c00594cc>] from [<c00a5c14>]
r7 = C01F9AE0 r6 = C012D8F4 r5 = C1FA5340 r4 = C010A82C
Function entered at [<c00a5bd4>] from [<c00a5d18>]
r6 = 00000001 r5 = C012D8F4 r4 = C012D948
Function entered at [<c00a5cc4>] from [<c00a5dd0>]
r8 = 00000000 r7 = C01F9AE0 r6 = C012D840 r5 = C012D995
r4 = C01F9B80
Function entered at [<c00a5d68>] from [<c00a5e1c>]
r8 = C009AC3C r7 = FFFFFFFF r6 = C00F4EE8 r5 = 00000000
r4 = C01F9AE0
Function entered at [<c00a5df0>] from [<c00a06e8>]
r4 = C011DF80
Function entered at [<c00a06d0>] from [<c00a0bf4>]
Function entered at [<c00a0bd4>] from [<c009c784>]
r4 = 000000FF
Function entered at [<c009c6b0>] from [<c00a0c18>]
r10 = C0008580 r9 = 4401A11B r8 = C01246E4 r7 = C010A788
r6 = C0123A30 r5 = C0102768 r4 = 00000001
Function entered at [<c00a0c04>] from [<c0046d10>]
Function entered at [<c0046d00>] from [<c0009ae0>]
r7 = C010A788 r6 = C0123A30 r5 = C0102768 r4 = 00000001
Function entered at [<c00099b4>] from [<c0009bb8>]
r8 = C0102988 r7 = C0102764 r6 = C0102760 r5 = C012D9AC
r4 = C0009BA8
Function entered at [<c0009ba8>] from [<c000b6ec>]
r7 = C0102764 r6 = C0102760 r5 = C012D9AC r4 = C0009BA8
Function entered at [<c00096c4>] from [<c00098b0>]
Function entered at [<c00096dc>] from [<c0008080>]
r7 = C0123F00 r6 = C0123E54 r5 = C012E3E0 r4 = C012E3E0
Code: e2833001 e58c300c (e59e2000) e3520000 e58c2000
Do these bootlogs tell me where exactly I need to look?
