To respond to my own post I just found from their FAQ:
If all of the members of the array are still functioning, it may be possible to recover your data. In the FastBuild BIOS utility, delete the array and re-create it [ IMPORTANT: Make sure that when you recreate the array you use exactly the same array settings (RAID level, drive assignments, and stripe size) of the original array ]. Going offline may indicate trouble with a hard drive, so it is recommended to perform a data backup and then perform a disk diagnostic on the hard drives.
So I guess I'll try that. I suppose it would be a good idea to do a block level copy of the drives first incase it decides to reformat the array in the process.
-Mike
