It seems to work in the car fine.I've only had the sigbus/segfault errors about 5 times.
I have the original home power supply that came with the player.When I plugged it in last night it wouldn't boot but tonite it did. here is the new boot log and new ram test.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v448 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Thu Mar 16 19:43:10 EST 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30103118) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004780).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xd0d0 -- FAILED
ide_data_test: wrote 0xffff read 0xd0d0 -- FAILED
ide_data_test: wrote 0xaaaa read 0xd0d0 -- FAILED
ide_data_test: wrote 0x5555 read 0xd0d0 -- FAILED
ide_data_test: wrote 0x0000 read 0xbbc4 -- FAILED
ide_data_test: wrote 0xffff read 0xbbc4 -- FAILED
ide_data_test: wrote 0xaaaa read 0xbbc4 -- FAILED
ide_data_test: wrote 0x5555 read 0xbbc4 -- FAILED
hda: FUJITSU MHR2030AT, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x045a -- FAILED
ide_data_test: wrote 0xffff read 0x045a -- FAILED
ide_data_test: wrote 0xaaaa read 0x045a -- FAILED
ide_data_test: wrote 0x5555 read 0x045a -- FAILED
hda: FUJITSU MHR2030AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2
e
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To Compìàlayer
redirected to /proc/ttyH
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
khttpd: listening on port 80
kftpd: listening on port 21
And the new ram test.
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id FUJITSU MHR2030AT
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 00
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
MIKE 80Gb RIO
