Check to see if Hypterterminal works. If not, then the upgrade won't work either. Instructions and troubleshooting steps are here.
Also note: If you were able to install Hijack before, then the serial port had to have worked at some point in the past.
Also note: The version of software you want to install is 2.0 final. Don't use 3.0.
