File - New - File - Script shows VBScript as a choice. I did that, typed in print, then tapped F1, and up popped an online help window. I can also insert a breakpoint.
Okay, you can insert a breakpoint. But can you begin executing the script?
I opened the existing script, it's all syntax-highlighted and everything, I can insert a breakpoint, but the play button and the debug/start command are grayed out. How about you?
