Making it conform from within Java is very difficult (because you need to special-case lots of stuff, like "if I'm on Aqua, buttons need to be X pixels apart
Haven't any of the UI builders gotten sofisticated enough that the layout of the UI can be made parametric? By parametric I mean that the placement of UI objects are defined with respect to each other instead of some absolute position in the window. Where the minimum size of a window is limited by the stackup of objects within it.
Ack.. Or is it just that those builders are still too expensive for widespread use?
--Glenn
the original post ate the paragraph spacing. I hope this edit fixes it.
It did. All I did was add these lines.
Edited by gbeer on 12/04/01 04:24 PM.
