That was it, Roger. The index was corrupted. I dropped it and recreated it, and now everything seems to be working.
Thanks you all for your help.
You need to be more precise. How did you "open the message table"?
It's a MSSQLServer feature. You can "show" a table, as Roger described, by simply using a specific GUI option.
Not being a SQL Server expert at all, I too believed that "showing" a table simply meant doing a "select..." .
It seemss that's not the case, instead. While a "select" uses the index (which was corrupted), "showing" a table reads the table directly.
And, thanks a_attrill for pointing to the GUI option to rebuild the index.
