The problem with using a DirecTiVo as a media streamer is the lack of support for anamorphic widescreen output.
Even with one of the Hughes high-def DirecTivo units? That one gives me control of the 4:3 TV shows and allows me to stretch them with the press of a button. Wouldn't it do the same for other playback?
I never even thought of that possibility. I don't know if show sharing works on the HR10-250. I know that you can extract from it though...
The Tivo_Zipper script will preserve your recordings as far as I know.
Interesting. Last I heard, the situation was thus:
- Stuff already saved to the Tivo hard disk was encrypted.
- Hacking the Tivo removes encryption from the algorithm that saves and plays back the movies, thus allowing any FUTURE recordings to be fully shareable. However, existing recordings would stay encrypted and couldn't be played back.
Maybe I interpreted this wrong, and actually what was meand was that existing recordings couldn't be *shared* with PCs or with other people because of the encryption.
In any case, I'd like to learn more, as hacking my Tivo is getting more and more appealing to me each day.
Un-hacked Stand Alone Series2 Tivos can share shows between each other and their recordings are still encrypted. I don't know if it would work the same way with DirecTivos because I have always hacked mine in a way that destroys the pre-existing recordings.
I don't think anyone ever bothered cracking Tivo's encryption since it's easy to just disable it. But yes, the encryption would disallow you from extracting your existing shows to a PC.
I've never used the Zipper, I don't know exactly what it does, but I think it just patches an existing image... it can even be an image of your drive (which is how you get to keep your recordings). As long as you have an image of your tivo, I don't think it's too risky to try the Zipper and see what it enables for you. It just takes time. Since it's an automated script, it's probably not too time consuming though.
