OK here is my log of pressing Control C, sorry!
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg55 (peter@tatu) (gcc version 2.95.3 20010315
(release)) #16 Mon Jul 25 18:54:48 BST 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read 9afffff0
empeg-car player (hardware revision 9, serial number 10101510)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: WDC WD600VE-75HDT1, ATA DISK drive
hda: WDC WD600VE-75HDT1, 57231MB w/8192kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e
6
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k initPlayer received SIGINT, user interruption
Switching to shell-player loop
cStarting bash.
no shell!
Shell exit
cPlayer received SIGINT, user interruption
Shell exit
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Shell exit
Shell exit
CProlux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
^HPlayer received SIGINT, user interruption
Starting bash.
no shell!
Shell exit
Starting bash.
no shell!
Shell exit
Vcb: 0x4073a000
Starting bash.
no shell!
Shell exit
Starting bash.
no shell!
Shell exit
Vcb: 0x4073a000
Empeg V2 60GB running v3 (alpha 11) and the autoupdated hijack from jemplode.
