highly recommend soldering up all the connections, even the ones you're not using, in case you want to sell the sled to someone else down the road. Might as well get it out of the way while you've got everything set up to do the work.
Yeah just be careful not to use too much heat or the insulation will shrink away from the strain relief in the connectors and shorten the life of your wiring.
Stu
