#296064 - 30/03/200719:48Re: Web help> clipped or click-through regions in images?
[Re: hybrid8]
tfabris carpal tunnel
If you don't want to use an image map, then you could theoretically do one giant image that you then slice up manually (and put it into a table in the HTML) and approximating the overall shapes. I used the product "Coffee Cup Image Slicer" to do this trick.
An example of a place where I did this is on the RioCar Button Guide, it's most obvious on the image of the faceplate, where I had to make links for the various sections of each button.
