I think the biggest challenge for you is going to be figuring out exactly how you're going to go about this, given that you're starting with DVDs. You're taking compressed video, and in most cases you're probably going to be compressing it again. I'd investigate to see if there's a way to do this without doing any recompression, but I've never gone that route myself, so maybe someone else here can offer some advice.
Every edit system I've used in the last 6 or 7 years that supports DV projects does not recompress unless it has to. As long as the input and output profiles match. But like Matt says, you're already starting off with pretty crappy quality.
