There'd still be the issue of mounting an antenna outside the faraday cage/steel empeg housing. The only 'harder' part would be supplying the 2.5V supply. It seems compact enough to mount to the rear or sides of the DIN cage, still requiring the RJ plug hack, but neater than a big old WET11.
If I end up moving forward with this part and get any, I'll post details.
-Zeke
WWFSMD?
