Well, no joy with that seemingly. Still have the same problem. Couple of issues I had whilst doing the procedure that you linked, Tony. When I typed the lines 'umount /dev/hda4' & 'umount /dev/hdc4' I got a bash error saying 'unmount no such file or directory'. Also, after typing 'fsck -fay /dev/hda4' and waiting a while, the player got to the 5th check and then even after 10 hours, I still couldn't type anything further in Hyperterminal. Had to reboot the player and shutdown/restart hyperterminal before continuing. Perhaps I should try the whole procedure again...
I logged the player booting and an attempt to upload some MP3s. I think the error is when I click synchronise, the player is rebooting rather than writing files or a new config. I can't even edit the config.ini file. Emplode states 'checking media' but the player is rebooting... log follows:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v477 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Jul 13 14:42:45 EDT 2007
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102438) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb84
Tuner: loopback=1, ID=-1
show_message("Hijack v477 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5555
hda: HTS548040M9AT00, ATA DISK drive
hdb: IBM-DJSA-210, ATA DISK drive
hda: HTS548040M9AT00, 38154MB w/7877kB Cache, CHS=4864/255/63
hdb: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:86
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: GMT
Hijack: intercepting config.ini
/drive0/var/ttsclock: getopts: `Option
': not a valid identifier
Saved AC volume was 33
Volume=33
emptris v1.3 starting...
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
empacman running as pid 23
Vcb: 0x4086d000
Adding Swap: 16028k swap-space (priority -1)
disk.cpp : 876:Couldn't cleanly unmount drive 0 (c0041010)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Restored terminal settings
Restart code received
Starting player
Timezone: GMT
Volume=33
empacman running as pid 52
Vcb: 0x4086d000
Steve
