#302063 - 12/09/2007 15:58
Re: Can't upload or change config...
Quote: OK, config.ini looked like this: ...
Cool. So you simply nuked the three EXEC lines:
@@ -79,9 +79,6 @@ buttonled_dim=5 buttonled_off=5 disable_bassboost_FM=1 -;@AC ;@EXEC /drive0/var/ttsclock -;@AC ;@EXEC /drive0/var/emptris -;@AC ;@EXEC /drive0/var/empacman [ir_translate] One.L=Clock Four.L=HijackMenu
Good luck!
One possible tip for people with a similar problem (extra programs running off of the music partition and therefore preventing sync from working), might be to prefix those lines with ";@AC ;@HOME ", instead of just ";@AC ".
That way you can enable/disable them on the fly (almost) using the HOME/WORK location selector on the Hijack menu.
