Absolute snake oil - at least for your application.
Look at the heat transfer mechanisms in play - conduction and air transfer are the major factors in a house. Radiative is minimal.
They *do* insulate well against radiative - so tests can show a reasonable performance cf rockwool etc. But in situ it's just not relevant. There are similar 'foil' linings for roofs - the consensus (including self-builders who've used them) is that they don't work. If this stuff did work then it would be used in applications like fridges + freezers. They still primarily use 'foam'.
I've been looking at this for *years* wrt building my own house. I've found that to make your house warmer :
* Identify draughts and block them - doors, windows, gaps in the floor (depending on construction). : this is the single best value action. A few pennies on draught exclusion can save a fortune. Of course it may already have been done.
* Loft/attic insulation : next best value job. Get a pro to do it - in the UK there are grants. http://www.energysavingtrust.org.uk/proxy/view/full/2019/grantsandofferssearch
* Cavity wall fill : not applicable but the next best
* If you are lucky and have good access under the floor you can fit insulation under there. Obviously not for concrete smile
After that the payback isn't worth it frown
Occasionally you get an opportunity to renovate and you may want to lose 4" off an external wall by using plasterboard over battens with well fitted insulation.
