All other aspects of operation seem nominal.
Including its home/car sensing?
As I recall, you daisy chain the empeg through another stereo before it goes to your amps, so you'd tend to have it set at full volume at all time and thus wouldn't necessarily notice right away if it was having the car/home sensing problem.
Home/Car sensing is working -- no fader available when plugged into the AC adapter, fader is available in the car.
The player isn't daisy-chained; I run it through a Sony switching relay so that if both CD player and empeg are turned on, the empeg gets priority; if the empeg is out of the car or in standby or turned off, then the CD player can operate.
When the empeg fails to start on car restart, it remains totally dead -- no display, no flashing blue standby light, nothing. Pull it out of the sled an inch and reseat it and it works normally.
