Also, if unplugging and replugging the firewire cable *works*, then there might be a software-only way of accomplishing the same task. I wonder if there is a command-line equivalent (or perhaps a third party utility) that can programatically disable/enable a driver in much the same way that you can use "net stop" and "net start" to bounce a Windows Service...
