Yep.
They went for form over function in a lot of ways on this one, and too far in some areas. The drive for example is limited to 80gb, because thats the largest single platter 1.8 inch drive on the market. The 160gb 1.8 inch drive in the iPod is a 2 platter design, and was too thick for the Air.
My hope is that by the time I want to buy, they have a second revision out with 4gb ram as an option. Keep in mind though for your use, 2gb may be enough. All depends on what you actually need to use the machine for. Based on what you said above, the only task likely to be hindered by that would be video editing, but only if you go to working with large files over the 3-5 minute clips you were talking about.
