So if you install one card only but set to slave is it still showing up as hda?
It sounds like either the master/slave isn't working or for some reason the cards you bought aren't supporting it correctly.
Position on cable should make no difference at all. It's simply a bus.
Edited by Shonky (03/06/2008 06:44)
Edit Reason: (added info about cable position)
