The tracks can be saved in order.. You have to set the outputted filename to be tracknumber_tracktitle. It is really quite flexible. Then, when you view the folder that the tracks are outputted to, they will be in alpha order. You can even change the "_" to a diferant symbol. Here is how to have the track number first:
Options>Settings... Then click on the "Recorder" tab. Click on the "Songs Directory" button. Now you can select where you want the mp3's to be put. I pick the desktop so that I can check out the files before fileing them away. Be sure to check "Track Number" under "Name Song using". The rest should be pretty easy to figure out...
Let me know if you have any other questions.. I've been using MusicMatch for about 6 months now...
32GB (JUST UPGRADED!) Mk. II BLUE
Detroit, MI USA
www.PfeifferBeer.com
Brad B.
