Thanks Bitt, that's exactly what I was hoping. So if these access points will be in a relatively straight line, I could just go from channel 1 to 6 to 11 and then start over again if I needed a fourth one?
Yup. I've done it before, and other than the fact that the APs I happened to be using were awful (they would just drop connections for no reason -- which they still did when I only had a single one running), it worked just fine.
